Wondering how to transfer styles individually between drawings in Civil 3D 2013.
Any help will be greatly appreciated.
Tim
Solved by dina0. Go to Solution.
Hi !!
You must have open drawings, choose the styles in the settings tab and carry them from one drawing to another
Hope that helps
You should be able to use the manage tab to import styles from one drawings into another also. You can also import drawing settings using the manage tab. The benefit to using the manage tab instead of the drag and drop method is you can import more than one style at a time.
