Valued Contributor
0 Kudos
Post 1 of 4
TRAFFIC STRIPE LINK FOR ASSEMBLY
168 Views, 3 Replies
12-03-2012 04:55 PM
I have an assembly with which I created my corridor model for visualization. My problem is how to insert a Subassembly link that will represent traffic stripes on the Corridor Model on 3D View. I will appreciate if anyone could walk me step-by-step towards achieving that. Attach is my assembly.
307 Kudos
Post 2 of 4
Re: TRAFFIC STRIPE LINK FOR ASSEMBLY
12-04-2012 10:14 AM in reply to: wizengr
Take a look at the Help for Code Set Styles.
Some of the lane subassemblies have a setting for Crown Point, which might default to No. Be sure this is set to Yes for one of the lanes that meet at centerline. You can use the crown as your traffic stripe.
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
Valued Contributor
0 Kudos
Post 3 of 4
12-04-2012 10:32 AM in reply to: tcorey
Suppose I want to have a 4-inch Striping in the middle of my Lane, how do I go about it having another link in the middle of the existing lane link?
Maybe something (like a line or link) has to be offset and raised above the existing Lane Subassembly
307 Kudos
Post 4 of 4
12-04-2012 10:47 AM in reply to: wizengr
I think I see what you're trying to do. You just trying to add a stripe for a plan view? Something you can quantify using Quantity Takeoff?
I would add a LinkWidthandSlope subassy from the Generic tab at centerline, running at the same slope as the lane, but half the lane width. Set Omit Link to Yes for this subassy. Then add another of the same subassy, but with OmitLink off and give it a unique link name. You can run it right over the top of the existing lane subassy.
Tim Corey, Owner
Redding, CA
