dont ask about top soil calculation!
autodesk just won't hear about it.
I did a search, and found lot of posts with no "autodesk replay" about this easy task.
i dont know what to do with a cross section that has no top soil drawn and calculated!
hey autodesk, should i calculate and draw the over 600 sections manually?
Your Name
Your Name
Your Name
Your Name
If you have a corridor design the stripping subs are the ideal tool for the job but this can also be done fairly easily with manual operations. Model needs to be rebuilt if the FG boundary changes
New file and import EG and FG.
Extract boundary for FG and convert to 2d pline if settings required
Offset boudary .1 units inside
Make new surface named 'EG Step 1 Lower' (or whatever you need)
Paste in EG and lower stripping depth, apply inner pline as outer boundary
Convert outer pline to fline and assign elev's from EG, add to a new surface named 'EG Step 2 Datum' (or what ever again 🙂
Paste Step 1 surface into Step 2 surface.
John Mayo
