Jon,
You are correct. The Add Contour Labels command is not honoring the setting
in the CreateSurfLabelLine category. This has been logged and is on the
list to fix. There should actually be 2 settings in that category, one for
the Major interval and one for the Minor interval. The missing tooltips has
also been logged.
thanks,
Dan Philbrick
"Jon Rizzo" wrote in message
news:6AD54E7E2F738716F33B0B2E9EFAC582@in.WebX.maYIadrTaRb...
> The tooltips for the "Create Contour Labels" toolbar do not appear to be
> working. Also, the "Add Contour Labels..." command does not seem to be
> respecting the default label style in the CreateSurfCntrLabelLine. Is
this
> the correct place for this setting? By default, it is set to "Standard",
> but when I run the command, it uses "Background". I also created my own
> style and tried to default to that, but it wouldn't.
> Jon Rizzo
> Langan Engineering and Environmental Services, Inc.
