Not sure what's going on and I guess it's not that big a deal but every once in a while the "Survey" and the "Toolbox" tabs disappear from my Toolspace. All I have to do is turn it off and then back on and it's fine but it's a little annoying. I haven't really tried to track down what I'm doing when it happens because I never notice it being goine until I need those tabs. Anyone else had this? Any ideas why? How about how to fix it? I game for anything.
Civil 3D 2011 32 bit (Server)
Service Pack 1 Installed
Dell Precision T3400
4 gigs of RAM (Why I don't know)
Windows XP Pro
Yes - Prospector and Settings disappear from my Toolspace now and again but turning off and back on fixes it - it's a bit random and no idea why it happens
My best guess would be a "flaky" installation. Have you tried a repair or re-install ?
I just spent the past month working on my first project using 2011 (upgraded from 2009). This was also my first project utilizing multiple gradings in combination with corridors to create a finished surface. I'm sure you can imagine some of the problems encountered with gradings alone.
Because of the multitude of issues I had to deal with, the missing Tabs as mentioned in this post were very minor, I just had to close and open the toolspace each time - no big deal at the time. Since finishing the plans I was able to look into some of these "minor" issues. I ended up deleting all of the Civil 3D registry entries and files/folders specific to my windows profile. Upon loading Civil 3D these files and registry entries are re-created giving a clean set of files. I have not experienced the missing tab problem since then (about a week now).
I wonder if it's a bug in the program, because I have the same problem. I've even uninstalled and reinstalled several times with the same results.
Others have complained of the same issue in other threads, so it's not an isolated problem.
Can you confirm whether or not you did a "clean" install ? Below is a link for instuctions.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14929539&linkID=9240697
I really appreciate everyone's input. I wanted to be sure it wasn't just me. I have to say though if so many people are haveing the same issue I doubt whether it has very much to do with the installation. Everyone can't be doing it wrong, right? Anyway, like I said originally, it's really not that big of a deal or at least not enough to lose a couple of man hours each for 12 operators while we try something we're not sure is going to work. I was just kind of hoping Autodesk might catch the thread and check in to this on their own and maybe take care of it. Time will tell.
I don't think it's so much an issue with how the installation is done but more of a problem with how the files are created and managed for each user profile. These files that are created for each user of the machine become corrupted and are what I beleve to be where the problem lies. How to prevent this from happening is something that Autodesk should spend more time with and come up with solutions that fixes the issue rather than slapping a band-aid on it (the clean install instructions).
We put in a support request regarding this issue in regards to the Prospector and Settings Tab. I posted this in another thread the other day, but I'll post it again, this is the response from Autodesk:
"Introduced in 2011 are two new commands to control the tabs displayed in Toolspace. In addition to the existing SURVEY and TOOLBOX commands which controlled the display of the associated tabs, now the commands PROSPECTOR and SETTINGS will control the display of these tabs. This was done as part of the memory optimization for the 2011 product. When these tabs are hidden the modules are unloaded from memory. Additionally these can also be toggled on or off from the Home tab of the Ribbon, in the Palettes panel."
For us, every hour or so the Prospector and Settings Tab disappears and only the Survey and Toolbox is left. We are having this issue on XP-32 boxes and W7-64 boxes. The 64 boxes are brand new, and the 32s are old.
My guess is that something is hosed in the new "memory optimization" code along with the new buttons they added. Maybe they can make it optional? Or just fix it?
This happens to me at least once a day. Is there a fix? Has anyone confirmed if a repair/reinstall will fix?
Civil 3D 2011 SP1
Windows 7 Enterprise
Intel Core i7 CPU 930 @ 2.80GHz 2.80 GHz
12 GB
64-bit
