Active Contributor
kclark138
Message 11 of 16 (312 Views)
Re: Toolspace Item View not working properly
02-11-2013 05:20 AM in reply to: tjhootman
I change the registry. It worked until I try to sort the column then it goes blank. This is a bug!
rkmcswain
Message 12 of 16 (306 Views)
02-11-2013 08:34 AM in reply to: kclark138
I don't think anyone is disputing the fact that it's a bug. The "fix" simply fixes the display problem......until you try and sort again, hence the last line in my earlier reply
andram-teco
Message 13 of 16 (279 Views)
03-20-2013 09:34 AM in reply to: mathewk
I was having the same troubles, and "Fix" worked. I don't even mind having to reload the lisp when I accidentally hit the "sort" button, because it's better than not having the list.
Thank you!
Member
jpierce8
Message 14 of 16 (258 Views)
04-05-2013 03:19 PM in reply to: rkmcswain
Had the same problem!  Cut and pasted the reg values for the imperial to the metric reg values and it seems to work.
(Imperial)
AeccMgrParcel:List:AeccMgrPltProspector:smileytongue:rospector
3;-1;9;1;0;0;1;0;0,100,1;1,60,1;2,100,1;3,90,1;4,70,1;5,100,1;6,100,1;7,100,1;8,100,1;
Member
jpierce8
Message 15 of 16 (253 Views)
04-05-2013 04:37 PM in reply to: mathewk
FIX works to view the parcels, but still does not resolve the column sort issue which causes them to disappear again and again and again?
mathewk wrote:
This fix is great, but still a bit of a pain.  i have created a LISP routine you can run that fixes this.  See attached.
This command is FIX.
When the bug happens, run this command, click to somewhere else in the prospector then click on Parcels again and you should see the populated list.
mathewk
Message 16 of 16 (251 Views)
04-05-2013 04:44 PM in reply to: tjhootman
I know, the procedure is:
Sort
Run the FIX routine
Every time you sort
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
