Windows 7. AutoCAD Civil3D r13 and 14.
Yes the toolbars are unlocked and even when they are locked using the ctrl key still will not alow me to resize. This used to work but now for some reason will not anymore. Any ideas as to why?
Solved by troma. Go to Solution.
Have you tried it with a different profile current?
Yes tried different profile. I can resize the propspector and properties windows but any floating toolbar like the dimension I can't. When I say resize I mean stack from a single row of icons to a double or triple.
Hi there,
The toolbar seemed to reset to its original size if you use the existing / default toolbar.
Try creating a duplicate of the toolbar and resize. It seemed to work.
See video:
http://www.screencast.com/t/LQj79VyfX9o
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Yes my co-worker can stack his too. Mine will not for some odd reason. I can see the outline of what the resulting stack would look like when draggin the corner but don't get the desired result.
Lim I tried the duplicate thing too. Still will not work. This is going on in both 2013 and 2014 C3D.
Can you try to load the cui attached to this post?
That will give a clue whether there's something amiss with your C3D.
If should load like the one in my video. Else, I'd suggest initiating a secondary installer
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21789329&linkID=9240697
Mark Green
Working on Civil 3D in Canada
