Civil 3D Forum
Tool Space (Missing "Edit Alignment Style" Command) at Prospector Tab
6 REPLIES 6
artbiscocho
793 Views, 6 Replies
HI All, I successfully created my alignment and profile design for my railway project. At my drawing I right click the alignment, click the "edit alignment style" and turned "off" all the "components"  and saved the file.
I opened my drawing again and wanted to see my alignment (with all the "components" showing). Under "prospector" I click "Alignment", "Center Alignment" and right click the File Name. I am expecting to see the "edit alignment style" but I can not find it. Since all the components on my drawing are all "off", I don't have any access to right click any "part" of my alignment.
To double check if my alignment is still active and not accidentally deleted on my drawing, I click "Inquiry" and I could still verify all the information. Meaning the alignment is still active.
Please help me to set or find the "Edit Alignment Style" under prospector tab.
Thank you all!!
6 REPLIES 6
Jeff_M
in reply to: artbiscocho
Click Properties when you right-click the alignment. On the Information tab you can edit the style.
Jeff_M, also a frequent Swamper
artbiscocho
in reply to: Jeff_M
Hi, Thank you for  immediate reply! Unfortunately I can not execute the "right click" procedure because all the alignment components on my drawing are all OFF. There is nothing on my drawing that pertain to my alignment.
Thank you again.
Jeff_M
Select it in Prospector.
artbiscocho
in reply to: Jeff_M
Thanks for your reply! That is my dilemma, the "Edit Alignment Style" is missing on the Prospector Tab. I can not find it or restore it.
Thanks...
Jeff_M
So you cannot edit the style from either of these 2 locations?
Alignment Properties:
Alignment styles:
artbiscocho
Hi Jeff, thanks for your help. You made my life easier today!!!
Art (Irvine, California)
Rail Community
