Civil 3D Forum
Tool Palette Problem
11 REPLIES 11
Message 1 of 12
sduffin
1103 Views, 11 Replies
In 3D 2011 when I open the Tool Palette which contains assemblies, materials, blocks, etc. -- the images for each item are not displaying.  A white space is shown instead.  Does anyone know how to resolve this issue?  Anyone else having this issue?
Scott
11 REPLIES 11
Message 2 of 12
AlmasSuljevic
in reply to: sduffin
Hi Scott,
Go to this location C:\ProgramData\Autodesk\C3D 2011\enu\Tool Catalogs\Road Catalog and check if you have an image folder. This folder contains the icon images used on the tool palette.
If it’s not there, you may need to manually copy it.
Also in Options menu>Files tab under Tool Palettes File Location make sure it points to (Windows 7): C:\Users\<user>\AppData\Roaming\Autodesk\C3D 2011\enu\Support\ToolPalette
Good luck!
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Autodesk, Inc.
Please click on "Accept as Solution" if post helped you resolve the issue.
Message 3 of 12
SethHall
Hi Scott-
Could you verify through the OPTIONS menu FILES tab that you have a path specified for your TOOL PALETTES FILE LOCATIONS? If not try adding it and see if that helps.
1162i13264C18AE1470D2
EDITING MY POST TO ASSIST WITH ALMAS' SUGGESTION
Seth Hall
Product Owner
Model Builder
Message 4 of 12
sduffin
in reply to: AlmasSuljevic
Thanks for the reply.  However, I am using Windows XP and do not have a ProgramData folder on the C drive.  I do have a Program files directory, but when I dig down it does not ahve an ENU directory.  I also looked under documents and settings, under my username - however I could not dig down through the path you indcate.
Any other suggestions?
Scott
Message 5 of 12
AlmasSuljevic
Then try...C:\Documents and Settings\All Users\...
Almas Suljevic
Autodesk, Inc.
Message 6 of 12
sduffin
in reply to: SethHall
I verified that it is pointing to this directory. Still no luck! Thanks, Scott
Message 7 of 12
AlmasSuljevic
Do you see Image folder and images in it?
Almas Suljevic
Autodesk, Inc.
Message 8 of 12
sduffin
IN this directory:
C:\Documents and Settings\scottd\Application Data\Autodesk\C3D 2011\enu\Support\ToolPalette\Palettes
There are many files ending with the .atc extension - but I do not see any images.
In this directory:
The same applies - no images.
Message 9 of 12
AlmasSuljevic
You should be seeing this:
1166i8EDE83B2282DE765
1164i5E167928EF64318D
Almas Suljevic
Autodesk, Inc.
Message 10 of 12
sduffin
This is what I see in the directory shown in the image below:  Must be some other issue!  Any other suggestions?  Thanks.
1168iF1F82E76FB8553AD
Message 11 of 12
sduffin
Here is what the tool palette looks like:
1170i0FA56FE4471C5375
Message 12 of 12
This is a really old post, but I never saw if anyone solved your problem.  We have had a similar situation.  In most cases, we have been able to right-click on the image (or blank box) in a tool palette and have it "Update the Image".
Rail Community
