Civil 3D Forum
tool palette dock and closed
12 REPLIES 12
Message 1 of 13
MonkeyTrainer
3795 Views, 12 Replies
i am getting a message when i click on something from my tool palette saying that it does not display when it is docked and closed. how do i undo this so i can use objects from the tool palette. how do i "unlock" it? see image.
thanks.
12 REPLIES 12
Message 2 of 13
AllenJessup
in reply to: MonkeyTrainer
CTRL + F3 should open the toolpallet. Then you can undock it if you want.
Allen
Allen Jessup
Engineering Specialist / CAD Manager
Message 3 of 13
MonkeyTrainer
in reply to: AllenJessup
unLOCK. it doesnt matter if its DOCKED or not
thanks.
Message 4 of 13
AllenJessup
Sorry. Should be CTRL + F1 for the Properties Pallet. Or select an entity, rt click and select properties from the menu.
Allen
Allen Jessup
Message 5 of 13
MonkeyTrainer
ok, maybe im not being clear enough. the objects on my tool palette are locked. thats it.
thanks for posting.
Message 6 of 13
AllenJessup
After rereading your post and the attached error. I'm thinking that the something you're click on in the toolpalette is a subassembly or other item that has properties editable in the Properties palette. So you need to open your Properties window.
Allen
Allen Jessup
Message 7 of 13
MonkeyTrainer
ok, there is nothing editable in the properties box referring to an object being lockable.
Message 8 of 13
AllenJessup
Or I'm being dense today. I don't know how to Lock a toolpalette so I can't say how to Unlock it. At this point my best guess is that you need to open your Properties Palette.
Allen
Allen Jessup
Message 9 of 13
MonkeyTrainer
do you know how to do that besides CTRL + F1? we changed our script for the f1 key.
Message 10 of 13
AllenJessup
We keep crossing our post. So your latest invalidates my latest. From reading the error message that was the best I could come up with.
Allen
Allen Jessup
Message 11 of 13
nevermind...
Message 12 of 13
AllenJessup
I docked my toolpalette and closed it. I then selected something from the drawing, did a right click and selected Properties from the right click menu. The Properties Palette opened. See if that works for you.
Allen
Allen Jessup
Message 13 of 13
MonkeyTrainer
fyi: i am working with corridor object off the palette. found out what it is. when i click on something off of the tool palette, the properties box is suppossed to automatically open; rightfully so, to edit the objects. mine doesnt open when i choose something off the palette. is there an (weird) option/toggle somewhere that will auto. open the prop. box?
Rail Community
