Distinguished Contributor
0 Kudos
Post 1 of 13
tool palette dock and closed
471 Views, 12 Replies
10-24-2012 10:07 AM
i am getting a message when i click on something from my tool palette saying that it does not display when it is docked and closed. how do i undo this so i can use objects from the tool palette. how do i "unlock" it? see image.
thanks.
fyi: i am working with corridor object off the palette. found out what it is. when i click on something off of the tool palette, the properties box is suppossed to automatically open; rightfully so, to edit the objects. mine doesnt open when i choose something off the palette. is there an (weird) option/toggle somewhere that will auto. open the prop. box?
485 Kudos
Post 2 of 13
Re: tool palette dock and closed
10-24-2012 10:13 AM in reply to: MonkeyTrainer
CTRL + F3 should open the toolpallet. Then you can undock it if you want.
Allen
0 Kudos
Post 3 of 13
10-24-2012 10:15 AM in reply to: AllenJessup
unLOCK. it doesnt matter if its DOCKED or not
thanks.
485 Kudos
Post 4 of 13
10-24-2012 10:20 AM in reply to: AllenJessup
Sorry. Should be CTRL + F1 for the Properties Pallet. Or select an entity, rt click and select properties from the menu.
Allen
0 Kudos
Post 5 of 13
10-24-2012 10:23 AM in reply to: AllenJessup
ok, maybe im not being clear enough. the objects on my tool palette are locked. thats it.
thanks for posting.
485 Kudos
Post 6 of 13
10-24-2012 10:24 AM in reply to: MonkeyTrainer
After rereading your post and the attached error. I'm thinking that the something you're click on in the toolpalette is a subassembly or other item that has properties editable in the Properties palette. So you need to open your Properties window.
Allen
0 Kudos
Post 7 of 13
10-24-2012 10:26 AM in reply to: AllenJessup
ok, there is nothing editable in the properties box referring to an object being lockable.
485 Kudos
Post 8 of 13
10-24-2012 10:26 AM in reply to: MonkeyTrainer
Or I'm being dense today. I don't know how to Lock a toolpalette so I can't say how to Unlock it. At this point my best guess is that you need to open your Properties Palette.
Allen
0 Kudos
Post 9 of 13
10-24-2012 10:28 AM in reply to: AllenJessup
do you know how to do that besides CTRL + F1? we changed our script for the f1 key.
485 Kudos
Post 10 of 13
10-24-2012 10:28 AM in reply to: MonkeyTrainer
We keep crossing our post. So your latest invalidates my latest. From reading the error message that was the best I could come up with.
Allen
