Civil 3D Forum
too many tin lines and warbles in my FG surface
4 REPLIES 4
MaryBell1
857 Views, 4 Replies
I have attached graphics to this question. I have this happening on several projects and I need to resolve this issue. I'm hoping it's just a setting. Its actually a couple of issues but I am thinking they are related.
(1) When I create my coridoor it seems like its creating far too many tin lines. Is there a way to have more control over this. (see image 1)
(2) The FG contours seem to be cruising down the road for a little ways then it appears as if it picks up an EG point then get back on track again.. ( see image 2). you can see the 'bow tie'.
     -my sub assembly checks out (its an inverted crown)
    -if you look at (image 3) you can see my FG looks good on my profile and based on my elev. on my plan it looks like its picking up the EG surface?
    -I have not pasted my EG and FG surfaces.... yet, and I may not.
(3) If you look at (image 4) you can see I have several of these 'warbles' . I can't figure out why it's just not using my sub-assembly straight through. If you look just below the 'bowtie' affect I noticed that it's not daylighting, it just drops off.
Thanks in advance!
4 REPLIES 4
odoshi
in reply to: MaryBell1
Did you use the correct FG Profile for that baseline, in Corridor Properties?
Mike
Mike Caruso
Autodesk Certified Instructor 2014
AutoCAD/Civil 3D Autodesk Certified Professional 2014, 2015, 2018
www.whitemountaincad.com
MaryBell1
in reply to: odoshi
HA.... thanks! Whew, I knew it was something simple I was overlooking. Now that that part is resolved I can see a couple minor issues that I will look at it with fresh eyes tomorrow before I accept this as resoved! Thanks for the quick response. Smiley LOL
Joe-Bouza
Now that the target issue is solved you can control the frequency of the corridor. You get TIN line for every corridor sample line
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People)
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win10 OS
neilyj666
in reply to: Joe-Bouza
Yes - best practice is to have the assembly frequency fairly wide initially while the design is progressing and then to reduce the frequency when it is time to finalise and compute volumes etc (and the frequency also depends on the EG topography)
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Rail Community
