Civil 3D Forum
Toggline Corridors in an XREF'd Drawing
4 REPLIES 4
CrazyIvan
240 Views, 4 Replies
Is there a way to toggle visibility of a corridor in a drawing where the model has been Xref'd into?
The problem I am having is that we have one Model drawing that has a corridor.
This Model is xref'd into multiple drawings.  Not all drawings should show the corridor.
The only way I have found so far is to go into model and toggle the corridor on and off depending on which drawing I want to print or view.  It creates problems when you want to run a Publish of multiple drawings because you always have to goof with the Model file.  This seems a bit of a step back from being able to toggle visibility of objects in a drawing file with an xref atached and leaving it that way and ready to be printed at any time.
Thanks.
4 REPLIES 4
Jay_B
in reply to: CrazyIvan
In the corridor object style the layers can be set to something such as C-Road-Corr and then can be frozen in drawings as desired assuming the xref is attached on layer zero and Visretain is set to 1 in the dwg's referencing corridor source dwg.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Lisa_Pohlmeyer
My workflow is exactly like Jay's.  We have our corridor object mapped to it's own layer.
Lisa Pohlmeyer
Civil 3D User
Website | Facebook | Twitter
CrazyIvan
in reply to: Lisa_Pohlmeyer
Sounds like a plan. I appreciate it.
neilyj666
Set modifiers for Object layers in your template - very useful
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Rail Community
