Civil 3D Forum
To create point from text file
14 REPLIES 14
Message 1 of 15
thanhtike.myn
6552 Views, 14 Replies
Hi,as i am a new user of civil 3D, i want to know how to create points from the text document file(.txt)
i encountered error when i tried to import the following file. Please share your knowledge,everyone.
Thanks & Regards
1130i25DA8F9275B5AC34
14 REPLIES 14
Message 2 of 15
dgordon
in reply to: thanhtike.myn
the only useful information in that file is the x,y,z below [points].   You can delete the rest of it.
C3D expects coordinates and elevations.   a common format that might work for this file once you delete all of the non essential elements might be PNEZ which stands for point, northing, easting, elevation.
the y is northing and the x is easting.
so format the info like this
1, 40629.0006,32887.9150,104.47
you can even do the PNEZD format and add a description to it like this
1, 40629.0006,32887.9150,104.47, manhole
Dan
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
Message 3 of 15
wfberry
You need to go to the HELP and look up Point File Format.
For example, one line of text would look something like this:
2,5000.00,6000.00,750.62,Nail in stump
This would be a PNEZD  comma delimited format.
All lines in this ASCII file have to be the same.  Nothing on the first or last lines except something like the above.
Quite frankly, it is difficult to see your text, even on my 30" monitor but it appears that your file may only have one point and that is near the bottom.
There are other formats including space delimited and the comma delimited mentioned above.
Bill
Message 4 of 15
thanhtike.myn
in reply to: dgordon
Dear Contributor,
Thanks for your solution.
So in order to import point from txt file,the format should be the one as you mentioned,right? (eg.PNEZD)
How many types of file that we can import into civil 3D, and what are the point file format?
And one more thing,a surface can only be created through points in Civil 3D?
if there's no points ,a surface cannot be created?
Than Htike.
Message 5 of 15
dgordon
surfaces can be created from many object types.   i.e. contours at elevation, 3d breaklines, 2d polylines as breaklines by proximity, autocad points, c3d points, lines, 3dfaces, blocks at elevation, any more that i cannot think of off hand at the moment.
Dan
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
Message 6 of 15
wfberry
You would be best served if you would go to the Help dropdown menu (far right and top of screen "?" mark) and select tutorials.  Go through all of these and you will get the proper manner and ease of accomplishing what you want.
Bill
Message 7 of 15
thanhtike.myn
in reply to: wfberry
Dear Contributors,
Thank you so much for your support.
After my research on tutorials,i wll be back and discuss with you about that.
Have a good day!
Thanhtike
Message 8 of 15
Dear contributors,
There's no tutorial drawing folder in my computer though i tried to follow the directions of help script. I think the files had accidentally deleted.
So how can i get it back,any downloading link for the files?
Thanhtike
Message 9 of 15
thanhtike.myn
If i have thousands of points in my txt file ..and i need to delete all of the unnecessary element in order to import points..so there is any way to manage the files in easiest and fastest way.
Message 10 of 15
wfberry
Without seeing exactly what your file looks like I would try importing it into EXCEL and working from there.  Remember, you have to save this revised file in ASCII format (text file) which you can do with EXCEL.  Do not save as an .xls file.
Bill
Message 11 of 15
thanhtike.myn
Bill,
can you please check the attached file and pls let me know how to manage those points into txt file and import into C3D.
i have to manage the file as
ID=1,X=32887.91506083,Y=40629.00065862,Z=104.47000000,C=red 14
into
1,32887.91506083,40629.00065862,104.47000000,red 14
this format,right? but i gotmore than 3000 points,so if i have to do it manully it will take time and very difficult.
so is there any fastest and easiest way to manage the file and import?
thanks & regards,
thanhtike
Message 12 of 15
Sinc
Here is the modified file.  What I did:
  1. Change the extension to .csv
  2. Open in Excel
  3. Sort all lines, so that lines starting with "ID=" were all grouped together.
  4. Delete all lines that did not start with "ID="
  5. Global Search-and-Replace, replacing "ID=" with an empty string
  6. Repeat last step for "X=", "Y=", "Z=", and "C="
Result is attached.  It took less than a minute.
I had to put the file in a .zip archive, because for some unknown reason, this forum won't let me attach a .csv file, believe it or not.
Sinc
Message 13 of 15
Hrabba
Do you use cvs or txt?
Message 14 of 15
Hrabba
Because I am also having problems with importing. And I have done absolutely everything recommended
Message 15 of 15
Pointdump
in reply to: Hrabba
Hi Hrafnhildur,
It would be best to start a new post. And please post your point file and a screen shot of the point file format you're using.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Rail Community
