"cadfreek" wrote in messageI
href="news:6036926@discussion.autodesk.com">news:6036926@discussion.autodesk.com...
still can't bind and explode my xrefs. There's always some struggle to get
anything to bind and explode in 2008. I must bind my xref because there is
some crazy coordinate bug. What happens is that the coordinates of the site
were originally in the 11,000,000,6,000,000 (x,y). Then one day the
coordinates start reporting in the hundreds. Nothing was moved. What's crazy
is that I attach this problem file to another xref that is reporting the
correct coordinates and it overlays my site perfectly, but not xrefing the
other way around! So I've fixed these coordinate file problems in the past by
starting a fresh new template file, bind the offending file, and wahlah, the
coordinates are back to normal for the rest of the project. This seems to work
best when there aren't many "intelligent" objects in the drawing. This
particular xref started exhibiting the coordinate problem after most of the
design has been done and now there are many "intelligent" objects. I can
bind-insert just fine, but when I explode the resulting block, my machine just
locks up. I got on a faster machine with more memory and was able to see it
attempting to recalculate my grading objects before it locked up, so I know
it's the more complex "intelligent" objects that are hanging it up the explode
block command. Why? Such a simple operation as bind and explode should not be
so complicated. Of course I have so many "intelligent" objects built off of
other "intelligent" objects that everything (surfaces, grading groups, sites,
etc.) would break if I were to copy-paste them or do a LandXML export-import
for the dynamic objects and copied over the manual drafting. It's always this
way on every project. I get wrapped around the axle of using "intelligent"
dynamic objects, like Civil 3D marketing says I'm supposed to. Instead I'm
just building ever higher platforms of complexity that crescendo into one
great big CRASH the day before the project is due to the client. I grow weary
of Civil 3D. PS- Tried attaching the trouble file, but the forum just gives me
the message "The content type of the file 'file.dwg' is not allowed." So much
for help with DWGs. Hope it's temporary system
glitch.
"Jeff Mishler" <miffATsonicDOTnet> wrote in message
href="news:6036908@discussion.autodesk.com">news:6036908@discussion.autodesk.com...
If you like, I will take a look at it for you. miff AT sonic
DOT net
by starting a fresh new template file, bind the offending file, and wahlah,
the coordinates are back to normal for the rest of the project. This seems
to work best when there aren't many "intelligent" objects in the drawing.
This particular xref started exhibiting the coordinate problem after most of
the design has been done and now there are many "intelligent" objects. I can
just locks up. I got on a faster machine with more memory and was able to
see it attempting to recalculate my grading objects before it locked up, so
I know it's the more complex "intelligent" objects that are hanging it up
the explode block command. Why? Such a simple operation as bind and explode
should not be so complicated. Of course I have so many "intelligent" objects
built off of other "intelligent" objects that everything (surfaces, grading
groups, sites, etc.) would break if I were to copy-paste them or do a
LandXML export-import for the dynamic objects and copied over the manual
drafting. It's always this way on every project. I get wrapped around the
axle of using "intelligent" dynamic objects, like Civil 3D marketing says
I'm supposed to. Instead I'm just building ever higher platforms of
complexity that crescendo into one great big CRASH the day before the
project is due to the client. I grow weary of Civil 3D. PS- Tried attaching
the trouble file, but the forum just gives me the message "The content type
of the file 'file.dwg' is not allowed." So much for help with DWGs. Hope
it's temporary system glitch.
"wfb" <
href="mailto:wfberry@bellsouth.net">wfberry@bellsouth.net> wrote in
message
href="news:6037648@discussion.autodesk.com">news:6037648@discussion.autodesk.com...
Jeff:
Did he take you up on your previous
offer?
Bill
sonic DOT net
site were originally in the 11,000,000,6,000,000 (x,y). Then one day the
crazy is that I attach this problem file to another xref that is reporting
the correct coordinates and it overlays my site perfectly, but not xrefing
the other way around! So I've fixed these coordinate file problems in the
past by starting a fresh new template file, bind the offending file, and
wahlah, the coordinates are back to normal for the rest of the project.
This seems to work best when there aren't many "intelligent" objects in
the drawing. This particular xref started exhibiting the coordinate
problem after most of the design has been done and now there are many
"intelligent" objects. I can bind-insert just fine, but when I explode the
resulting block, my machine just locks up. I got on a faster machine with
more memory and was able to see it attempting to recalculate my grading
objects before it locked up, so I know it's the more complex "intelligent"
objects that are hanging it up the explode block command. Why? Such a
simple operation as bind and explode should not be so complicated. Of
course I have so many "intelligent" objects built off of other
export-import for the dynamic objects and copied over the manual drafting.
It's always this way on every project. I get wrapped around the axle of
using "intelligent" dynamic objects, like Civil 3D marketing says I'm
supposed to. Instead I'm just building ever higher platforms of complexity
that crescendo into one great big CRASH the day before the project is due
to the client. I grow weary of Civil 3D. PS- Tried attaching the trouble
file, but the forum just gives me the message "The content type of the
file 'file.dwg' is not allowed." So much for help with DWGs. Hope it's
temporary system
glitch.
why not attach dwg thru xref
can you send me the site or information on a different solution
thanks and Happy St Pats Day
dj
