Civil 3D Forum
TIN/VBA
1 REPLY 1
288 Views, 1 Reply
TIN/VBA
Is there a way to programmatically
(VBA or somehow else) get
the coordinates of endpoints
for TIN lines?
I understand FindElevationAtXY
surface object's method detects
Z for given XY, but I'd like to get
XYZ for TIN vertices (the endpoints
of TIN lines).
thanks
Strah @ Langan
1 REPLY 1
Strah,
To get an array of the entire list of XYZ coordinates for the TIN surface
you can use the Property:
AeccTinSurface.OutputTriangles
This will give you an array of all the vertices of the triangle edges for
the TIN surface. It looks like we should extend this and add a method to
FindTriangleAtXY, which would return the edge vertices for a specific
triangle. That method has not been exposed.
Daniel Philbrick
"Strahimir Antoljak" wrote in message
news:468C71CEFBF37ED773454E3516B629AF@in.WebX.maYIadrTaRb...
> for TIN lines?
> of TIN lines).
> thanks
> Strah @ Langan
Rail Community
