Active Contributor gk
Active Contributor
gk
Message 1 of 3 (289 Views)
Tin Surface question
289 Views, 2 Replies
10-20-2012 03:12 PM
I have set up the linework code set and the figure prefix database where I noted which figures were to be breaklines. I then imported the ASCII coordinate final to the survey database, processing the linework as it is imported. I create a surface then modify the surface by importing a point group and create a tin, but the figures in the drawing are not being recognized as breaklines.......what am I doing wrong ?
Garry
GarryK
Hard to say...  C3D has LOTS of settings that can create a problem.
But my first guess is that you didn't select the breaklines in the Survey Database and do Right cliick->"Insert Breaklines".  If you've already tried that, and it fails, then it's probably a settitng in your Desc Keys, your Figure Prefix Lib, or your Styles/Layers.
Sinc
Message 2 of 3 (278 Views)
Re: Tin Surface question
10-21-2012 01:05 AM in reply to: gk
Sinc
Active Contributor
gk
Message 3 of 3 (241 Views)
10-22-2012 05:03 AM in reply to: gk
Thank you, Sinc - that was my problem. I've checked out the help files and gone through the process again. I understand now how it works.
Garry
GarryK
