I have TIN surface. And I have set contour color by layer. If "Elevation" setting are turned off surface countors are by layer. If "Elevation" setting are on, contours becames of color set in color scheme. I have attached images of it.
Can I keep my contour colors by layer if I turn "Elevation" setting on?
Solved by doni49. Go to Solution.
You could try taking your contours off layer 0.
Mike
As in something like this?
Don Ireland
Engineering Design Technician
Yes this is it.
But it's odd they made it like this.
If contours are in layer 0 or the same layer as surface, contours will be in color of elevation first color. But if contours are in deferen layer they will be in color of layer.
