drafter1411
Message 1 of 6 (210 Views)
tin lines
210 Views, 5 Replies
01-28-2014 01:00 PM
why do my tin lines go through my break lines? I'm new at tin modeling and breaks.
I created an existin ground from points I manually put in. I drew a poly line and created points along that line with elevation 108. I also have other 108 elevations in the drawing. I added a break line between the line I drew with the points on it and the points out side. re build surface and tin lins crossed the break making my contour look jagged.
Go to surface properties, Definition tab. Be sure the order of operation in the bottom of the screen has the breaklines being added after all other point sources.
neilyj
Message 2 of 6 (203 Views)
Re: tin lines
01-28-2014 01:07 PM in reply to: drafter1411
Can you be more specific or better still post an example
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 500Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
drafter1411
Message 3 of 6 (196 Views)
Re: tin lines
01-28-2014 01:17 PM in reply to: neilyj
tcorey
Message 4 of 6 (186 Views)
Re: tin lines
01-28-2014 01:36 PM in reply to: drafter1411
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
neilyj
Message 5 of 6 (138 Views)
Re: tin lines
01-29-2014 02:48 AM in reply to: drafter1411
Can you post the dwg?
neilyj
drafter1411
Message 6 of 6 (92 Views)
Re: tin lines
02-03-2014 02:39 PM in reply to: tcorey
sorry taking me this long to get back to you had the flu. But I redrew the breakes and it works fine. I had added points after break line thanks for your help.
