Civil 3D Forum
tin lines
5 REPLIES 5
drafter1411
352 Views, 5 Replies
tin lines
why do my tin lines go through my break lines? I'm new at tin modeling and breaks.
5 REPLIES 5
neilyj666
in reply to: drafter1411
Can you be more specific or better still post an example
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
drafter1411
in reply to: neilyj666
I created an existin ground from points I manually put in. I drew a poly line and created points along that line with elevation 108. I also have other 108 elevations in the drawing. I added a break line between the line I drew with the points on it and the points out side. re build surface and tin lins crossed the break making my contour look jagged.
tcorey
Go to surface properties, Definition tab. Be sure the order of operation in the bottom of the screen has the breaklines being added after all other point sources.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
neilyj666
Can you post the dwg?
drafter1411
in reply to: tcorey
sorry taking me this long to get back to you had the flu. But I redrew the breakes and it works fine. I had added points after break line thanks for your help.
Rail Community
