Using image import in Planning and Analysis workspace to import georefed tif. Comes in great except it come in black and white. Is a color image. Come into ArcGIS in color. I don't see a setting to change. A jpeg of the same image, non georefed, comes in in color using the same command, just have to align it. Image is 3 GB.
If you used Data Connect to bring in the image check the style settins and make sure its to full color.
Murph. I had not set that to full color. Turns the image blue. I didn't see any other settings. I will poke around a bit tomorrow and see if I can tweak it. Thanks for the reply.
