When I print out a file with contour line labels, I get a tick through the center of the text- it seems to be associated with the grip edits for the text. I tried changing layer names, but even when I get the tick on layer that is turned off, it still appears on the plot. See attached pdf- thick isgoing through the second zero in "900". thanks.
Solved by Jeff_M. Go to Solution.
