Hello guys,
Mey PC has this specs:
OS: Windows 8 Pro x64
Processor: Intel Core 2 Quad Q9550 @ 2.83GHz 12MB Cache
Motherboard: Gigabyte GA-G41MT-S2P
RAM: 2x4GB DDR3 1333MHz
SSD: Samsung 840 EVO 250GB SATA 3
HDD: Seagate 1TB 7200RPM SATA 3
VGA: Gigabyte GTX 550 Ti 1GB GDDR5 192-bit
This is a good PC to AutoCAD Civil 3D 2014?
There is a little problem with my PC. When I open this topographic plant in my PC this happens.
Can someone help me? What is happening?
God bless you!
Your graphics card is not an Autodesk Certified graphics card.
Also, what exactly is happening? You are opening the drawing in vanilla AutoCAD, not Civil 3D, and I don't see anything bad happening. You are 3D orbiting.
It's slow when I'm orbiting. Can you see? It's impossible to work like this. The same problem happens in the Civil 3D. The video only shows my problem.
Is the problem with my machine?
God bless you!
If you want to orbit, the best way to do this is to hold the SHIFT key down, then hold the mouse wheel down to orbit. It's much smoother.
I did it, but the problem is the same. I'm thinking that is a bug. What do you think about this?
