In AutoCAD Civil 3D 2012 when assigning the state plane coordinate system LA83-SF is missing from the Library. Although it is visible as a choice to select in the Available coordinate systems window when creating a Category. Is there a fix for this?
It looks like they changed it to "LA83-SF-MOD"... They've been really bad at these coordinate systems, and keep changing them from release to release... Hopefully switching to the new definition will fix any issues you have.
Oops, sorry Todd, I was looking at the "solution" flags, and didn't realize you said the same thing as me... I skipped over your answer.
I do appreciate the both of your trying to answer this question. I am in CADD Support and we just swung the kitchens door from MicroStation to AutoCAD. I had some training in AutoCAD Civil & Map 3d 2012. Is there any chance of AutoDesk analyze this problem and reply so I can give the user a developer answer?
