Active Member
0 Kudos
Post 1 of 7
Text wont delete or edit
442 Views, 6 Replies
07-26-2012 12:18 PM
I have text in a drawing that wont edit or delete. I have heard there was a text bug and to fix it set DTEXTED to 1. I have done that, closed out and came back in and the text is still there and will not delete or edit. Any ideas?
485 Kudos
Post 2 of 7
Re: Text wont delete or edit
07-26-2012 01:04 PM in reply to: tbrown
Is it some sort of Label? What do you get if you list it?
Allen
Active Member
0 Kudos
Post 3 of 7
07-26-2012 01:40 PM in reply to: tbrown
No its just the text you get under annotate. Like Multiline text etc Tiffany Brown, IE | Design Engineer Alfred Benesch & Company | 3226 Kimball Avenue, Manhattan, KS 66502 P 785-539-2202 | F 785-539-2393 | E tbrown@benesch.com | W www.benesch.comThe information contained in this message may be privileged, confidential, protected from disclosure or subject to copyright/patent protection. If the reader of this message is not the intended recipient, or an employee or agent responsible for delivering this message to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us immediately by replying to the message and deleting it from your computer.
485 Kudos
Post 4 of 7
07-26-2012 01:43 PM in reply to: tbrown
Locked layer? Try wblocking some to a new file and see if it still behaves badly there. If it does, post the file so we can take a look at it.
Allen
Active Member
0 Kudos
Post 5 of 7
07-26-2012 01:54 PM in reply to: tbrown
Okay I got it fixed. A co-worker messed around with it and changed "PICKFIRST" to 1 and that fixed it. Yay! Tiffany Brown, IE | Design Engineer Alfred Benesch & Company | 3226 Kimball Avenue, Manhattan, KS 66502 P 785-539-2202 | F 785-539-2393 | E tbrown@benesch.com | W www.benesch.comThe information contained in this message may be privileged, confidential, protected from disclosure or subject to copyright/patent protection. If the reader of this message is not the intended recipient, or an employee or agent responsible for delivering this message to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us immediately by replying to the message and deleting it from your computer.
485 Kudos
Post 6 of 7
07-27-2012 05:48 AM in reply to: tbrown
Glad you found the problem.
Allen
Valued Mentor
43 Kudos
Post 7 of 7
07-27-2012 06:53 AM in reply to: tbrown
Tiffany,
The PICKFIRST variable controls whether you select objects before or after you use a command. This is known as noun-verb selection.
PICKFIRST = 0 turns off pickfirst, which means that you select objects after you use a command.
PICKFIRST = 1 turns on pickfirst, which meanst that you select objects before you use a command.
You can also get to this setting if you go under the AtuoCAD options. Options-->Selection Tab-->Selection Modes.
Hope that helps.
-Owen
Windows 7 x 64 bit
NVidia Quadro K3000M Dual Monitor
32.0 GB RAM
Intel Core i7-3820QM @ 2.70 GHz
Civil 3D 2013 SP 2
______________________________________________________________
Usually, I find that the problem is between the keyboard and the chair.
