Civil 3D Forum
Text question editing in properties
2 REPLIES 2
kmedeiros1
241 Views, 2 Replies
okay i know you can use the style command or change to mtext, but it is just one word i want to change from normal to bold.  this is where i am at:
command: "dt"
typed my word and finished command
selected my word i just used and right clicked, selected properties.
in the properties menu, under text is the contents.  contents is shows what word i created.  just as typing %%d creates a degree symbol, i know there is a code to type to make it bold, italic or whatever.  my question is what is that code?
Tags (3)
2 REPLIES 2
rkmcswain
in reply to: kmedeiros1
deltacoolguy
command: "dt"
I am not aware of anything within DText ("dt" command) that will allow bold.  To the best of my knowledge bold is only available in MText.  In MText it's pretty easy and MText has become pretty powerful and flexible over the years to the point that I am using DText less often... though I do still use it some.
In MText Edit you just slect the word you want, or the whole thing if applicable, and pick the "B" button on the ribbon.
Windows 10-64 Pro
8GB RAM (Home)
12GB RAM (Work)
AutoCAD Civil 3D 2019
Rail Community
