Civil 3D Forum
Text orient from xref
6 REPLIES 6
chrishaarmeyer
2801 Views, 6 Replies
I have created a base plan that has lot numbers for a subdivision.  I have created the text style to align with the viewport orientation and it all works correctly.   I would like to xref that base plan into other blowup sheets and have the lot numbers scale and reorient to the new respective viewport.   The lots scale correctly but do not reorient, any ideas.
6 REPLIES 6
wfberry
in reply to: chrishaarmeyer
Do you have the Orientation Reference set to VIEW?
Bill
chrishaarmeyer
in reply to: wfberry
Where do you find that?  It sounds good.
Sinc
It's in the Style setting.
Unfortunately, I have not found this setting to work through XREFs...  😞
Sinc
Location to set the orientation reference for label styles.  And it does work from an XREF. See the second image. The parcel drawing was referenced and the UCS for that viewport was changed. Worked perfectly.
I did get it to work.  I just didn't get into a viewport in the linked drawing to see that it would rotate through the viewport but not in Modelspace.  Thanks.
Hi all,
I have been having a similar issue with MLEADERS.
Is there a way to have a MLEADER in a base file rotate to be plan readable in an XREF file's ritated viewport?
We typically use MLEADERS not notes/labels.
thanks for any help.......
Rail Community
