Active Member
cmhguy01
Message 1 of 7 (691 Views)
Text orient from xref
691 Views, 6 Replies
05-17-2011 01:40 PM
I have created a base plan that has lot numbers for a subdivision.  I have created the text style to align with the viewport orientation and it all works correctly.   I would like to xref that base plan into other blowup sheets and have the lot numbers scale and reorient to the new respective viewport.   The lots scale correctly but do not reorient, any ideas.
wfberry
Message 2 of 7 (684 Views)
Re: Text orient from xref
05-17-2011 01:48 PM in reply to: cmhguy01
Do you have the Orientation Reference set to VIEW?
Bill
Active Member
cmhguy01
Message 3 of 7 (682 Views)
05-17-2011 01:50 PM in reply to: wfberry
Where do you find that?  It sounds good.
Sinc
Message 4 of 7 (672 Views)
05-17-2011 02:41 PM in reply to: cmhguy01
It's in the Style setting.
Unfortunately, I have not found this setting to work through XREFs...  :smileysad:
Sinc
jane
Message 5 of 7 (634 Views)
05-18-2011 06:04 AM in reply to: cmhguy01
Location to set the orientation reference for label styles.  And it does work from an XREF. See the second image. The parcel drawing was referenced and the UCS for that viewport was changed. Worked perfectly.
Active Member
cmhguy01
Message 6 of 7 (632 Views)
05-18-2011 06:09 AM in reply to: cmhguy01
I did get it to work.  I just didn't get into a viewport in the linked drawing to see that it would rotate through the viewport but not in Modelspace.  Thanks.
Active Contributor
rainmanoliver1
Message 7 of 7 (569 Views)
10-13-2011 12:37 PM in reply to: cmhguy01
Hi all,
I have been having a similar issue with MLEADERS.
Is there a way to have a MLEADER in a base file rotate to be plan readable in an XREF file's ritated viewport?
We typically use MLEADERS not notes/labels.
thanks for any help.......
