Civil 3D Forum
Text Linetype Flips at Nodes
3 REPLIES 3
494 Views, 3 Replies
I am using AutoCAD Civil 3D 2013 and just installed HotFix 3 (so I should be all up to speed).  I have created a water linetype (---W---) and telephone linetype (---T---).  The problem I am having is the 'W' and 'T' seem to flip at some of the nodes based on if the Polyline is going up or down (from left to right).  When it is going up it displays right side up...going down it displays upside down.  They are one single polyline with nodes.
I have tried REVERSE, PEDIT then Reverse, my linetype definition is set to U=0.0, but nothing has worked.  I have redrawn other polylines and they all have the same issue.
Attached is a PDF of the polylines.
Any thoughts?
3 REPLIES 3
One more thing to add, when I draw polylines in Paper Space I do not have this issue.  So it has something to do with the polylines in Model Space which is how it displays in the viewport.
I believe you just have to remove the u from the code
*UTELE,telephone line
A,.375,-.027922,["T",Line Text,y=-.05,s=.1,u=0],-.092644,.75,-.08,.08,-.08,.375
Thanks DMARTIN!  Worked like a charm!  Robot LOL
Rail Community
