I recently updated to autocad civil 3d 2015 from 2014. When I opened any drawing that I created before the update all Text in all Layouts in paper space has disappeared! Unfortunately I did not notice this right away and now I have a drawing where I have lost all text in paper space in every layout tab, is there any way to retrieve this lost text?? I have searched forums all over the web and cannot find anybody that has had the same problem. Please Help
P.S. if I don't save the drawing and someone else in my office opens the same drawing the text appears as it should but if I save the drawing then text disappears for everyone.
Solved by hjesus87. Go to Solution.
hjesus87 wrote:P.S. if I don't save the drawing and someone else in my office opens the same drawing the text appears as it should but if I save the drawing then text disappears for everyone.
What version are the other users using to open those files which behave normally?
Can you post the file? Maybe someone here can open it and find something. I don't have access to 2015 so I can't test it myself but that might shed some light on the subject.
Don Ireland
Engineering Design Technician
It seems like this is only happening with files created by AutoCAD Map 2010. I have actually resolved the issue with some help. It seems like it had something to do with the saving down of the file to version 2007 and the fact that the text was annotative. So what we ended up doing is the following;
Be sure you’re in Paperspace. At the command prompt, paste the following code and press Enter:
(setq ls (ssget "x" (list (cons 0 "MTEXT")(cons 67 1))))
Then, at the command prompt, type Select. When it asks to select objects, type !ls and Enter until back to the command prompt.
On the Properties dialog, change the Annotative property to No
Hope this helps anyone stuck in the same situation!
Thank you to all that replied.
