AutoCAD Civil 3D General Discussion
Distinguished Contributor
martin888888
Message 1 of 3 (437 Views)
Text Height
437 Views, 2 Replies
03-02-2011 02:04 PM
In a metric drawing I am trying to get some text styles set up for text labels and titles.
1) In the properties dialog box what units does it measure height in?  Doesnt look like its millimeters.
2) In paper space you can size your text to a normal 3/32" or 1/8" text hieght.  How do you set up text in model space so it comes in correctly (correct size) in paper space?  Do you need to know the paperspace viewport scale ahead of time to add the correct text sizing to your profiles and misc text?
*Expert Elite*
Joe-Bouza
Message 2 of 3 (430 Views)
Re: Text Height
03-02-2011 02:42 PM in reply to: martin888888
if you are seeing inches I would thing your drawing was not setup with a metric dwt file
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
miked
Message 3 of 3 (417 Views)
Re: Text Height
03-02-2011 03:01 PM in reply to: martin888888
I am assuming that you are referring to plain text and not Civil3D labels.
1) The text height is millimeters.
2) Create a annotative text style with the paper space height set see below and set current. Now you can create the text in your model spaces once you have created the text you need to add all the possible viewport scales to the text via properties.
3) When you have created your viewport set your viewport scale and from the viewport properties make sure you set the viewport annotation scale to the viewport scale.
You must remember you are working in metric not imperial so you cam not mix the two 3/32 and 1/8 don't exist
NVIDIA Quadro 600
Civil3D 2012 64x
Need installation help?
