Hi, I opened a drawing today and the text in the multileaders is 10x's too large as you can see in the attached screenshot of construction keynotes.
It was fine when I closed it yesterday and I was the last person to open the drawing.
Multileaders in both model and paper space are affected.
I've tried:
Anybody seen this before or know a fix?
I suspect this is a random error without a fix and I'm going to have to delete all the multileaders, purge the drawing, and redraft the multileaders, or do what I did before annotative multileaders: use dynamic blocks I created for making callout notes. Ugh.
Solved by johnthoreson. Go to Solution.
I've also tried:
Could you post a screen shot of the properties window after highlighting the multileader?
My English is not very good I hope I understand, this error has happened to me when I copied from one drawing to another Multileader, text, blocks with attributes.
What has worked well is to create text styles, Multileader, dimension styles in a palette as "blocks", when used in a new drawing copy of my custom palette I need and there is no such problem.
Never copy drawing to drawing, if you know any other solution how to edit a variable, please ask them published.
RA Arq.
Figured out what went wrong: attributed text height spontaneously reset itself to a paperspace height of 2.5 (should be 0.125) in the blocks _TagCircle and _TagHexagon being called by the multileader styles.
Here's the fix:
Mark Green
Working on Civil 3D in Canada
