Hi Everyone,
I have been using a "Text for Each" label component to get my connected pipe inverts displayed on my structure label on my profile views, but now, we'd like to get them in the pipe data band along the bottom. The problem is that there is not "Text for Each" option when adding label data to a structure on the band.
How can I get the inverts of pipes that are connected to a structure to display in the data band? For instance, three pipes connected to a manhole.
Ideas?
Hi Anthony,
Try this:
On the Profile View Properties, bands, when you choose the "Band type" scroll down and make sure you choose "Pipe Data", and pick a band style that have Invert Elevation information then you can edit the "Pipe Network Band Style" go to Band Details and you will see on the right side labels and ticks, type, pick on "Structure" and go to Compose Label to modify text contents, go to text component editor, scroll down and under Properties you will find more options. You can add info for pipes too.
D
Not a band style as you want but a work around.
Create an empty band, then create a structure label that imitates what you want in the band, set the anchor to the bottom of the profile view (if that is where your bands are) with a negative offset to put it into the band.
