Where can i find Text Component Editor in Civil 3d.
THanks
Kulfi,
Clicking on the Ellipsis will bring up the Text Component Editor:
Dave
Dave Stoll
Las Vegas, Nevada
Kulfi,
You can only access the Text Component Editor in a Label Style. If you're trying to change some text, it depends on what kind of label it is. If the text is a MultiText, then right-clicking will allow you to choose the text editor.
Can you post a Screen Shot of what you want to do?
Dave
Dave Stoll
Las Vegas, Nevada
Kulfi,
It'll be in one of these two Styles:
Dave
Dave Stoll
Las Vegas, Nevada
Kulfi,
If you want to change the radius, you can do that in several ways:
1. Grip Edit the Radius the usual AutoCAD way.
2. Depending on what the radius represents, the contextual ribbon will show a Geometry Editor.
3. Properties.
Dave
Dave Stoll
Las Vegas, Nevada
When you say you want to "change the radius", do you mean you want to change the precision shown? Or change the actual radius? If the latter, then PointDump has you covered.
But if you're wanting to change the DISPLAY of the radius, that's done via the Profile View Label Band Styles.
Don Ireland
Engineering Design Technician
@Kulfi wrote:
Ok after I select profile view band style after that I need to go to the label where the radius id
Take a look at the screenshots I previously posted. After you click on "Compose Label" (step 3), you'll be able to update the radius item there.
Don Ireland
