I am using Civil3D 2011 and I am working on 1:1 model space scale. When I go to paperspace and open a scaled viewport, the texts and linetype scales change. What can i o to make them look the same as in model space?
In the both the base and sheet files use these settings (if 2 separate files)
MSLTSCALE=1
PSLTSCALE=1
LTSCALE=1
Set the MS Scale and VP scale to desired project scale.
This way the MS scale and VP scale set your linetype scales.
We have these variables set as shown in all of our dwt's so users don't have to worry about anything
other than which VP & MS scales to use.
Hi, my model sp[ace scale is 1:1 and my paper space viewport is 1:75 on A1 (page setup of scale 1:1). I have tried using the 3 commands but it is still changing my linescales and text height. What is it that I am still doing wrong??
Rick Jackson
Survey CAD Technician VI
Here are a few copied words from previous post to hopefully give you a better understanding. There are tons of previous post regarding this issue.
sinc wrote:
> In modelspace, C3D labels will scale
> according to the Annotation Scale. But that does not seem to be the
> case in paperspace viewports. In paperspace, all C3D labels scale
> according to the viewport scale, not the viewport's annotation scale.
> So while it is technically possible to set the annotation scale in a
> viewport different than the viewport scale, this has no effect on C3D
> labels. The C3D labels will always use the viewport scale.
Brian Hailey wrote:
> Technically, the labels do not scale to the annotation scale, they
> scale to the drawing scale or the viewport scale. When changing the
> annotation scale in model space, the drawing scale is also changed.
There was similar issue like this where all the annotation scale chaging when doing a regen in Paper space.
It was fixed by changing the Toolspace->Drawing Settings->Custom scale to 1:1000 and drawing units to Meters.
