Civil 3D Forum
Temporary File (As XREF) slows drawing
2 REPLIES 2
287 Views, 2 Replies
I'm working on a rather large subdivision (not uncommon, certainly used to a longer-than-normal load time) but have found one of our XREF files to be bringing drawing loads to a screeching halt. We have XLOADCTL set to 2, which explains the creation of the temporary file.
I have previously gone into the file and reset the scale list, which helped speed things up by about 50%, but today it appears to be doing the same thing.
Is there anything I can do to prevent this from becoming a more serious problem? Can I add some sort of SCALELISTEDIT reset command to the acaddoc.lsp file?
2 REPLIES 2
troma
Coincidence, this is from earlier today:
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Field-for-Viewport-Showing-XREF-Scale-First/m-p/39151...
Mark Green
Working on Civil 3D in Canada
dgorsman
in reply to: troma
From experience, be a little cautious with blindly using the "Reset" option on the scales list.  If the file has been pared down to a handful of scales and the default list has more than that (it usually does), you can actually end up adding more scales to drawings.  The good news is there are a couple of very nicely done scale list control LSPs in the LISP forum which allow for much finer control of what to do with the list of scales in a drawing.
Rail Community
