Civil 3D Forum
Templates and Point Groups
7 REPLIES 7
Message 1 of 8
MtnMax700
457 Views, 7 Replies
Can you create point groups in your template to be used by all drawings or do they have to be per dwg.?
Thxs.
David
7 REPLIES 7
Message 2 of 8
rl_jackson
in reply to: MtnMax700
Yes you cand have this setup in your template.
Rick Jackson
Survey CAD Technician VI
Message 3 of 8
ToddRogers-WPM
Yes.  You can also create surfaces using those point groups in your template, so when you import points, your surface is automatically created.
Todd Rogers
Message 4 of 8
Joe-Bouza
in reply to: ToddRogers-WPM
Hi Todd,
I loved that technique, but I the problem I had was I would have these empty surfaces in the prospector for all my drawings. I thought about different tplates for surfaces but I didn't think it was worth monitoring many templates.
How do you do? Many templates or just delete the empty surfaces as you go?
Your Name
Message 5 of 8
ToddRogers-WPM
in reply to: Joe-Bouza
Well I'm not in production, so there is no need for me to have that in my template file.  If I was in production, I would have just the one template file with one surface for existing ground.
Todd Rogers
Message 6 of 8
Joe-Bouza
Thats my delema. I have one template file for production so every drawing gets created with an EG in it. It can get confusing after the "real" eg gets DS into other production drawings with this prototype eg already in it. Am I making sense?
Your Name
Message 7 of 8
ToddRogers-WPM
AAAH, I see your delimma.  That does make sense.  That would probably end up causing some serious problems down the road.  Maybe rename the one in the template to be something else?  Otherwise, just don't create one in the template.
Todd Rogers
Message 8 of 8
Joe-Bouza
Yeah, I gave up on it. I principle ita a great idea. I went all out making emply surfaces, pipe networks, aligments profiles, corridors, point groups all of it. Works great when you are in a bubble but not in production
Your Name
Rail Community
