Since you used the verbiage "template" captainsepoto, I'll need to assume
you mean this is happening in LDT/CD?
I've seen this happen quite often in my years with Civil Design.
You should check to make sure that there's a LK# file in your Template
Folder, and then you can delete it of course.
And just to make sure here - C3D now refers to their "replacements" as
Assemblies, when you make use of them in Corridors right?
Don Reichle
"The only thing worse than training your staff, and having them leave is -
not training your staff, and having them stay." 😮
A reminder taken from Graphics Solution Providers' Calendar page
!! Please discuss whatever we tell you with your SysMgr !!
!! They appreciate staying in the loop 🙂 !!
LDT-2K4
AMD Athlon64 2.2GHz 2GB RAM
XPPro 32bit SP2
WD Raptor 10K-rpm 37GB HD
Nvidia GeForce FX 5200 128MB
"The only Constant is Change".
wrote in message news:5539256@discussion.autodesk.com...
This is in regards to Civil3d 2006 as installed over Land Desktop 2006. I
keep getting a message that tells me the template I am trying to edit (edit
template command) is locked by myself. Has anyone encountered this before?
