Hey there,
We have recently started using a feature code library with our trimble survey gear and have been processing the lineowrk and exporting the lines as a DWG and the points as a CSV and when iput them in the same DWG in Civil3D the point and Line Vertices are exactly on top of eachother. Does any know how to fix this? I dont know if its to do with rounding, LSF, or projection to Cartesian??
Any help would be great
Thanks Richard
If I was shooting points in the field for linework I would expect the lines to be on the point. What are you expecting?
Do you want flat linework for plotting? If so copy the file, explode and flatten. If you need to maintain feature line curves, flatten the featurelines before exploding.
If you need something else let us know.
John Mayo
