When I try to redo my corridor it gives me a warning
target object not found
this is difficult first project in civil 3d and they want it NOW
hard to set this up and finish a rush job
all pays the same ...ha ha
Solved by mathewkol. Go to Solution.
So it's a warning and not an error? This is a very important distinction to make. If it's a warning, there could be nothing wrong with the model. If it's an error, then there probably is.
Expand the eerror; which subassembly is it referring to? Is is an offset or elevation error? If it's an alignment warning, then you probably have width targets set, but those targets don't exist for the entire length of the alignment and that's no problem.
Are you actually seeing something wrong with the corridor? No, then it's likely not a problem.
I edited my alignment to include more area
I then wanted to update the corridor to include this
rebuild didn't seem to change it
so I went to create a simple corridor
I pick the alignment
then the profile then the assembly
the event viewer comes up with a red error and says on description target object not found Target DTM
keep in mind we jumped from 2005 to 2010 it's somewhat like starting over
so I'm new at this but determined to learn it
thanks for the help
Are one of your subassemblies suppose to be targeting a surface? Is a surface assigned in the Target dialog for the region(s) producing the errors?
John Mayo
So that means that you have not set a surface target. Probably for your daylight or something.
you are right i didnt set a surface target
we are so strapped
styles are still being set up and on a rush
ok one error at a time
thanks for your help
much appreciated
