Kristina,
One way that you could do it is to make your own assembly using the
"generic" subassemblies. Start with two "LinkOffsetAndSlope" one on each
side, and then two "LinkSlopeToSurface". You will need to use negative
offset on one of the link offset and slope.
Then, you make two additional alignments, for the edge of the ditch lines,
with the taper that you want to use (in plan).
Let me know if you need more information on how to do this.
Peter Funk
Autodesk, Inc.
