Civil 3D Forum
Tags in parcel
10 REPLIES 10
Message 1 of 11
arturopolanco
612 Views, 10 Replies
Tags in parcel
I have two parcels in a single site.
But when editing the labels want to renumber the tags of According to the corners of the parcels. Independently of a parcel and another parcel.
Example:
Parcel A (L1, L2, L3, L4)
Parcel B (L1, L2, L3, L4, L5)
But elude this Parcel B with tags (L5, L6, L7, L8, L9). A continuation of the numbering of the tag
Arturo Polanco
AEC Solutions Specialist - Civil Infrastructure
Web | Moodle | Youtube | Instagram | Twitter | Facebook | MeWe | VK
10 REPLIES 10
Message 2 of 11
They have to be on separate sites in order to do this.  You can't have duplicate tag numbers on the same site.
Todd Rogers
Message 3 of 11
To subdivide the parcels, is need on the same site. But I want to know if there is any other way to achieve this result without using tags.
Arturo Polanco
Message 4 of 11
Jeff_M
in reply to: arturopolanco
After you've created the tags you can renumber them and specify to Create Duplicate numbers:
Jeff_M, also a frequent Swamper
Message 5 of 11
ToddRogers-WPM
in reply to: Jeff_M
Forgot about that one Jeff.  It's Monday and I've had only a half cup of coffee so far.  Thanks for the catch!
Todd Rogers
Message 6 of 11
wfberry
I am not contradicting what Jeff has said but am questioning your use of the "L?" tag.  In your drawing, for instance, L7 represents the length and bearing of a line, which you already have labeled.  L7 is not a corner point.
Tags are used to make a table.
Bill
Message 7 of 11
Jeff_M
in reply to: wfberry
Bill, my guess is that this is a plat which is being referenced in a description which uses the tags to denote which line is being called. I've seen a few surveyors around here use a similar method.
Message 8 of 11
wfberry
in reply to: Jeff_M
Thanks Jeff
I think I will go and re-paint some of my old paint buckets.
Bill
Message 9 of 11
arturopolanco
in reply to: Jeff_M
Exactly Jeff. It's just a description.
Arturo Polanco
Message 10 of 11
arturopolanco
in reply to: Jeff_M
My site has many parcels. the only way is to do it one by one.
Arturo Polanco
Message 11 of 11
Jeff_M
Yes, one by one. Can't even make a program to automate it as the Tags are not exposed to any of the API's.
Rail Community
