Civil 3D Forum
Tag Table object selection
2 REPLIES 2
IanMcClain
495 Views, 2 Replies
I've got a bunch of tags with a dedicated "tag mode" style, and if I select them individually I can add them to a table, no problem. However, if I try to do a mass selection of a swath of labeled lines or arcs i get the option to convert all non-tag labels to tag lables (I don't want that) OR don't add those labels not in tag mode (presumably keepin those that are). The problem I have is if I select the latter it deselcts everything. Am I missing something or does this not function as it implies (or at least how I wish it would)?
Ian McClain
Tags (2)
2 REPLIES 2
rkmcswain
in reply to: IanMcClain
If they are all the same style, can't you just toggle on that style in the selection part of the Table Creation dialog?
R.K. McSwain     | CADpanacea | on twitter
IanMcClain
in reply to: rkmcswain
I have them on different layers for some overlapping sheets. So for instance, I want a table that uses all of the Line Tag styles that are on the sheet 4 layer and another for sheet 5.
Ian McClain
Rail Community
