Valued Contributor
thanhtike.myn
Message 1 of 12 (954 Views)
Tag for parcel label
954 Views, 11 Replies
03-14-2011 06:44 AM
Hi all,
when we create tag for parcel labels n create table, why the tag number in the table are out of order like L1,L2,L5,L10..?
Can we arrange the tag number in order?
And how to edit that tag table?
Rgds,
Thanhtike.
dasindog
Message 2 of 12 (952 Views)
Re: Tag for parcel label
03-14-2011 06:59 AM in reply to: thanhtike.myn
You can handle that by editing the table style.
-Dustin
Civil 3D 2013 64 bit SP1
Windows 7 Pro 64
Intel Xeon 2.93GHz
24GB RAM
NVIDIA Quadro FX 580
explodetheblock.wordpress.com
Valued Contributor
thanhtike.myn
Message 3 of 12 (927 Views)
03-15-2011 02:55 AM in reply to: dasindog
If you don't mind,can you please discuss in detail.
I want to know the steps.
Thanks.
Rgds,
Thanhtike
Joe-Bouza
Message 4 of 12 (921 Views)
03-15-2011 05:20 AM in reply to: thanhtike.myn
Choose edit table style and select the check box for sort labels assessing/ descending.
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
New Member
devganesh
Message 5 of 12 (895 Views)
03-16-2011 01:29 PM in reply to: thanhtike.myn
by selecting the parcel property, then click on renumber/rename then assign your starting number
Active Member
Deertick
Message 6 of 12 (824 Views)
03-24-2011 07:43 PM in reply to: thanhtike.myn
To edit the Tag Table you can right click on it and select "table properties" from the menu or in your toolbar menu under table/properties. Once in the edit dialog box you can edit the text that goes into the table by double clicking on the text. You can also edit what info goes into the table like bearing, radius, length ect. The only thing that i haven't found out is how to size the actual column height of the table. Hope that makes sense for you.
New Member
devganesh
Message 7 of 12 (814 Views)
03-25-2011 05:56 AM in reply to: thanhtike.myn
thank you for your help.
Valued Contributor
david.dixon
Message 8 of 12 (727 Views)
07-27-2011 08:11 AM in reply to: thanhtike.myn
I believe this is a bug in the software. (C3D 2012)
For instance...I have a closed polyline which has lines and curves.  Using tag labels numbering the lines and curves get automatically labeled like this.
L1, L2, C1, L4, C2, L6, C3, C4, L9
The curves get automatically numbered consecutively but the lines do not.  The line numbering takes into account the curves with the numbering.  The curves ignore the lines and work fine.
It needs to be fixed by Autodesk.
David Dixon
Senior Civil Designer
Google+
Valued Contributor
david.dixon
Message 9 of 12 (718 Views)
07-27-2011 09:38 AM in reply to: david.dixon
...and to add on...
If I try to edit the tag label from L3 to L2, any table I have in the drawing already will not update with the edited tag.  It will list the original number.  Looking at ways to do this in PowerCivil. not happy
David Dixon
Google+
Valued Contributor
david.dixon
Message 10 of 12 (712 Views)
07-27-2011 09:57 AM in reply to: david.dixon
ok, somewhat happy again...I found a workaround...
If you change the polyline to an alignment, then the line tag labels get numbered consecutively like they should be.  I had no luck with the line numbering with changing the polyline to a parcel.
And I did not really want to open PowerCivil :smileyhappy:
cheers!
David Dixon
Google+
