kettledrum
Message 1 of 5 (484 Views)
Synchronizing data shortcuts breaks reference to alignment in profile labels
484 Views, 4 Replies
09-06-2013 06:58 AM
I have some storm sewer alignments that I've put into profiles in C3D 2011.  The pipe network that I used to create the alignments from is a reference created from a data shortcut.   I've created profiles of these storm sewer alignments, and the station labels for the storm structures are displayed at question marks until I go into the structure properties for each structure and link it to the correct alignment.
The problem is that whenever I synchronize my data shortcuts because someone has updated something, all of the links in each structure to the alignments disappears and I am back to ??? for my stations in the profiles and I have to go go fix it again.   I'm sure there is a better way.  Anyone have any ideas on how to keep this from breaking?
I do see this recent message http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Station-Label-update-problem/td-p/4401905  that appears to be a similar problem, but it was said in that thread that this problem was introduced with C3D 2012, but I am using C3D 2011.....
Jeff_M
Message 2 of 5 (463 Views)
Re: Synchronizing data shortcuts breaks reference to alignment in profile labels
09-06-2013 09:11 AM in reply to: kettledrum
This is an issue that has been around since the dawn of Dref's. Changing the referenced alignment for a structure is not retained, although I certainly wish it would. What does work is to change the reference alignment in the label...select the lable, go to the properties palette, change it there.
kettledrum
Message 3 of 5 (458 Views)
09-06-2013 09:30 AM in reply to: Jeff_M
Thanks for your reply.  I tried doing as you said.  However, in the properties box for the structure profile label, the only choice I have for Reference Alignment is <default>, none of my alignments are showing up there.
Jeff_M
Message 4 of 5 (455 Views)
09-06-2013 09:52 AM in reply to: kettledrum
CLick the little 'select' box on the right edge of the line where it says <default>. It's not obvious because the prompt is now on the command line to select the reference alignment on screen or you can hit Enter to select from a list.9-6-2013 9-49-55 AM.png
kettledrum
Message 5 of 5 (452 Views)
09-06-2013 10:01 AM in reply to: Jeff_M
Aha, that's it.  You're right, I ws missing the call back to the command line for input.  Thank you very much for your help!
