I'm not up to speed in configuring title blocks with sheet set manager and I've come into this situation unexpectedly.
I had to come up with a set of P&P sheets in a hurry to assist a contractor in providing a rough estimate for a sewer run, so I generated the sheets using the preconfigured imperial sheet set template. Afterwards I've switched out the border and title block generated by the template with our standard blocks. Our block attributes are old school and do not use fields. Now I am trying to upgrade those old attributes by replacing them with fields that reference the Sheet Set attributes.
Here is the problem: when inserting the field for the sheet number I can either use the CurrentSheetNumber or the SheetSetPlaceholder attribute. If I use CurrentSheetNumber, the title block shows the correct sheet number for the current sheet (the sheet I am making the edits from). However all the other sheets show that same number. In other words the fields do not show the corresponding sheet numbers from SSM. If I use SheetSetPlaceholder none of the title blocks will update to show the sheet number.
I believe I should be using the placeholder field but I can't get it to synchronize it with the SSM. Is there a way to make this work?
Your Name
Your Name
Your Name
Your Name
You shouldn't need the fields as part of the block definition, thats redundant.... no? I'd make everything NOT intended to be controlled by the sheetsetmanager in a block definition and everything else as mtext (or dtext).
i initially desired to have a block/xref for borders with everything in it and soon learned what you are now learning... there's no need to have fields bound into a block :-)... but if you do it, as long as all the fields point the correct place you can explode a block and it'll adopt the attributes, that's pretty impossible to do with borders/sheets because a sheet typically has both field types SHEETSETCUSTOM and SHEETCUSTOM....
short answer, avoid fields in blocks you don't intend to explode
EDIT: we have a dwg file saved as dwt file with all the title block fields linked to a "blank" sheet set and use the dwt and the example sheet set to get desired results.... it is quite tricky though.
My border is a block and the text is a seperate block which is just the attributes for the sheet title block. By keeping the text in a block (vs. just text copied into each sheet) we can modify the text styles and move the text within the block as needed to accomodate unanticipated changes that may arise, and all the sheets update.
Ok well, that only works if all of your sheets are in 1 drawing.... unless you are trying to xref the info into multiple dwg files... i guess if you have multiple sheets in 1 dwg file there is an advantage to using a block for this...
i can't help you with placeholder, i've never used it because i link directly to the ssm from dtext or mtext which is setup in our dwt file and linked to an example ssm.... anything not ssm driven is not a field and needs to be edited per sheet so why bother with fields and blocks....
anyways, your ok with everything except fields in the att block.... that just doesn't work in my experience. I've not been able to update fields in a block because the field won't act independantly within the block...
now in this post http://forums.autodesk.com/t5/AutoCAD-2013-2014-DWG-Format/Fields-in-Block-Not-Updating/td-p/3609834 Volker says it works if the text objects are dtext...
you're still going need battman to fix the attributes text styles and whatnot.
I respectfully disagree with your assesment of SSM and block attributes. The intent of SSM is to control fields primarily in attributes as well as text objects.
You may wish to investigate the BlockPlaceHolder because in you own work flow you are manually assigning SSM fields directly to dtext or MTEXT, presumably to reference one sheet from another in a callout. See Detail <X> on draing <Y>, and View port titles and scale. The BPH is designed to do just that( ever wonder what the View tab is for? Keeps track of your plan callouts.). I suggest you get a hold of the White paper "Sheets Happen"
The use of SSM in Blocks and text is only limited by the users imagination.
Your Name
Your Name
LIke i said, i'm not familiar with placeholder.... don't typically need it but I'll take a look at it and thanks for the suggestion.
Our details are xref'd into sheet drawings and we use BMP with the 3 tier drawing approach (1 sheet per drawing) so we'd have to xref a border into our sheets to update all of the borders...
Your Name
Your Name
http://heidihewett.blogs.com/my_weblog/files/Sheets_Happen.pdf
sorry, yes we do use SSM, have since day 1 but we don't use fields in blocks often.
best practices guide->project management->drawing and object relationships->level 3 production sheets
essentially everything is an xref accept the border, and we only create 1 sheet per cad drawing. so each construction plan has it's own sheet instead of 35 construction plans in 1 cad file... therefore, having the border as a block is useless really, it would have to be an xref to be effective at changing 1 thing in the border on all sheets at once....
Let’s assume you are working on a plan and profile sheet. First, create a new drawing, name it, and save it to your working folder. Then, externally reference the appropriate Level 2 drawings, such as base linework, base utility, and base topology. When you create a Level 3 drawing, the Level 2 object data and label styles are display-only. However, you can use Layer Manager to selectively hide and display layers within the Level 2 data.
If you use Vault, be sure to use the option Include All File Dependencies when you check in the plan set drawing. This ensures that all associated file dependencies are copied to their working folders when other team members check out the plan set drawing.
You typically use a plan set drawing with Sheet Set Manager (SSM) in AutoCAD Civil 3D. To create individual sheets in SSM, you create AutoCAD views within your plan set drawings. For more information about SSM, refer to the online help in AutoCAD Civil 3D."
Most of our projects are small site grading plans so we can get by with all the sheets in one file. When we get into larger projects or cases where the plans need to be broken out into subsets (i.e. grading, utilities, etc.) then we'll XREF the border. That is why we have the title block attributes in a seperate block vs. the border. Thus we can make global edits to all the sheets by editing the border XREF and global edits within each subset by editing the attribute block.
Very common practice.
All that gobaltgook about levels vault yadayad is great to know and does not sound all that different than xrefing my data set. That includes my title block
If I may ask how exactly do you use SSM in your work flow for filling out sheet info? And when do you insert field directly from SSM? I ask because I think we are talking about the same thing and this "TitleBlock" talk is confusing the discussion.
Your Name
Your Name
we have a template for non-sheet drawings
and a template for sheet drawings.
the sheet drawing has fields in dtext and mtext that are linked to an example sheet set.
we create a new drawing from the non-sheet template
then import the layout tab from the SHEET template.
When you add the TAB/SHEET to the SSM all of the fields link correctly to the SSM made from the Example SSM.
We don't need blocks for our borders... because changing the border requires approval at the highest level, because that is a part of (edited out YOUR BRAND for OUR BRAND) our brand.
Your Name
Your Name
Might one of you be able to figure out my issue?
I have made a sheet set that I use, BUT when I add a sheet or save an existing sheet with a new name and edit the fields thru the SSM, It doesn't take? I have to edit the fields in the drawing by right clicking the field, pick edit field & then point to the correct file in the field editor box. Why don't my fields update after I edit from right clicking the file in the SSM? This is also true when I add a new sheet, which is the template I created to use for this purpose.
The only thing that works correctly are the fields, drawing file name & the fields that are Sheet Set controlled. Not my custom fields which are sheet specific?
Any help is GREATLY appreciated!
Thanks, Mark
Might you be referring to callout blocks? If so, I have no experience with them, but the following might help:
http://www.allaboutacad.com/downloads/Automating_Views.pdf
No, But thanks for the inquire.
Send me your sheet file and dst file.
jbouza<at>cameronengineering<dot><com>
Your Name
Your Name
Take a look at the attached files.
The title block is inserted as a block. All the fields are in ATTRIBUTES. The attributes are setup (in the block editor) with the Default Value being the field.
P.S. You will need to change the sheet properties so that it can find the dwg file in its new location.
Don Ireland
Engineering Design Technician
