Does C3D11 contain a symbol library for things like the north arrow, handicap symbols and the like?
chaz_
Solved by AllenJessup. Go to Solution.
Check the Tool Palletes - they have all sorts of sample content.
There's also tons of free symbols if you search the web.
HTH
AWood
Try Design Center [CTRL+2].
Allen
Allen Jessup
Engineering Specialist / CAD Manager
You're welcome. I presume that means you found it. I wondered why the reply to your post bombed out.
Allen
Allen Jessup
As mentioned. Design Center is well suited for this. You can also add any blocks you want to a ToolPalette. Any block you use regularly should be part of your template.
We only use 2 different north arrows. One for plans and one for presentations. Both are in our template and can be accessed by the Insert command.
Allen
Allen Jessup
