Civil 3D Forum
Symbol Manager in Civil 3D 2013
17 REPLIES 17
Message 1 of 18
kepano530
8532 Views, 17 Replies
Does Civil 3D 2013 have a Symbol Manager as LDD did?
If not can I bring in the symbols from LDD 2007?
Looking for the Utilities menu that featured this.
17 REPLIES 17
Message 2 of 18
Joe-Bouza
in reply to: kepano530
Its old but may help
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Symbol-Manager-vs-Tool-Palettes/m-p/1519611#M12356
Your Name
Your Name
Message 3 of 18
Jay_B
Im not familiar with the LDD symbol manager but Civil 3d does have some symbols that come with the installation. They can be found at C:\ProgramData\Autodesk\C3D 2013\enu\Data\Symbols\
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 4 of 18
kepano530
in reply to: Jay_B
I'm using C3D 2013 in the Infrastucture Design Suite and there is no such folder in the installation.
Message 5 of 18
wfberry
Try DC (Design Center) and see what and where something pops up.
Bill
Infrastructure Suite 2014
Message 6 of 18
Joe-Bouza
found them
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=8891614&linkID=9240697
Your Name
Your Name
Message 7 of 18
Hi Joe,
This question about symbol manager in C3D 2013 was presented to me today.
That is not the reason for this post.
You have the link http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=8891614&linkID=9240697 indicated as where you found them.
I am curious if the content of your link was changed with the advent of the Autodesk Knowledge Network?
Kyle
Message 8 of 18
kepano530
in reply to: wfberry
What I found worked for us is to create a templaTe with all the symbols (from LD2007) available withi the file. I accomplished this using DC.
Message 9 of 18
wrighte
Here's the current link to that article: http://knowledge.autodesk.com/support/autocad-civil-3d/troubleshooting/caas/sfdcarticles/sfdcarticle...
Eric Wright
Sr. Web Product Manager
Message 10 of 18
kepano530
Thanks for the link but it points to a subfolder that doesn't exist on my system. I did a search for such and nothing.
Running Autodesk Infrastructure Design 2013 on Windows 7 Pro.
Message 11 of 18
wrighte
Unfortunately, my expertise ends with new web site, hoping someone with more product expertise can jump in here to help...
Eric Wright
Message 12 of 18
wrighte
Eric Wright
Message 13 of 18
Jay_B
\ProgramData\ happens to be a hidden folder.
What happens this setting is changed in Windows Explorer?
Organize>Folder and Search Options>View Tab>Hidden Files and Folders>Show hidden files, folders and drives - check this
Now C:\ProgramData\... should be visible in Windows Explorer.
Edit, I believe the AutoDesk link provided contains a typo as these folders are normally installed under C:\ProgramData\...
C3D 2018.1
C3D 2016 SP4
Message 14 of 18
kepano530
in reply to: Jay_B
Unfortunately that isn't it either. I don't have that folder. However, I used this folder C:\Program Files\Autodesk\AutoCAD Civil 3D 2013\Sample\Symbols to place the drawing files of symbols from LD2007 that I created and that works. Just curious why good pieces of software don't trickle down thru the stages of upgrades. It seems that end users don't have as much input as would seem logical. My 2 cents.
Message 15 of 18
Pointdump
in reply to: Jay_B
Jay,
"They can be found at C:\ProgramData\Autodesk\C3D 2013\enu\Data\Symbols\"
Whenever I need to find something where that "enu" is part of the path, it doesn't seem to exist on my computer. Search comes up empty. No "enu" folder anywhere.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Message 16 of 18
jmayo-EE
John Mayo
Message 17 of 18
jtuohy
in reply to: Jay_B
Jay B. is correct. You can also open up the design center and navigate to the path.
Message 18 of 18
BushW
Hi @kepano530
Yes, I remember the LDD symbol manager. Great tool back in the day!
I suggest taking a look at your tool palettes (civil) tab to see what they have to offer for utility symbols. Then I recommend using the Design Center to build your set symbols for your tool palettes (civil) tab.
Here is <<video>> showing some of the capabilities of the Design Center and how to pick drawing files apart and extract various components from them. It can also be used when working with tool palettes. Hope this helps!
Please select the ‘Accept as Solution’ button if my post solves your issue or answers your question so, other Community members may benefit.
Wendell Bush
Civil Infrastructure Technical Support Specialist
Rail Community
