I am trying to move my layer system to the NCS. For items that have a "symbol" as the node, do you have a layer such as "V-SYMBOL-ELEC" for power poles, peds and other equipment and then a layer "V-NODE-ELEC" for locating the under ground utilities? Right now I have all nodes/symbols going to "V-NODE-ELEC" and the text going to "V-NODE-TEXT".
My problem is that I want the under ground nodes to go away but then my symbols go away also.
Thxs.
David
Solved by MtnMax700. Go to Solution.
The NCS template out of the box is a format go-by. If you need layer to suit your needs, add them as you wish
Joe Bouza
I may be wrong but I believe the layer classification for your electric power symbols should be V-POWR-*, not V-NODE-*.
Use the handy dandy point group for the underground stuff and set it blow the NO Display group wala there gone
Rick Jackson
Survey CAD Technician VI
@ Mtnmax - We also encountered similar frustations when trying to adopt the very same standards you described. We setup new layers for every point that had a symbol. In the case of a power pole the symbol would go on the V-POWR-SYMB layers while the associated text would go on a V-NODE-POWR-TEXT layer. It was a little different at first but it works great and allows us to freeze and thaw the point text and symbol independent of each other.
I am thinking that is a better way to go than Point Groups. I have people that don't have that much experience with Autocad-let alone CIVIL3D. layer control is far easier to explain.
Thxs
David
