machadt
Message 21 of 27 (1,028 Views)
Re: Switching to model space hangs civil 3d 2012
12-14-2011 03:19 PM in reply to: jbarsic
Please go to Option -> System tab -> and under Layout Regen options select Cache model tab and all layouts (Apply and OK).
In some cases this can be drawing specific, please check that as well.
Tatiana Machado
AEC-ENI Application Engineer
jbarsic
Message 22 of 27 (1,024 Views)
12-14-2011 03:31 PM in reply to: machadt
also LAYOUTGENCTL 2, correct?  Cuts me down to a 6-7 second lag before cursor responds again.  Little irritating but useable and hopefully when I get our RAM issue resolved it will speed up a little.
Still curious about some BIOS settings so I guess I'll start another thread and hopefully someone can jump in.
Thnx
John
machadt
Message 23 of 27 (1,021 Views)
12-14-2011 03:51 PM in reply to: jbarsic
Yes, keep the LAYOUTREGENCTL set as 2....
Tatiana Machado
gte959s
Message 24 of 27 (670 Views)
01-11-2013 01:33 PM in reply to: machadt
Did this solve the problem? If not, did you find a solution?
jbarsic
Message 25 of 27 (666 Views)
01-11-2013 02:39 PM in reply to: machadt
With the latest updates from AutoDesk for Civil 3D 2012 and the ATI FirePro AutoCAD Maximum Driver our machines are useable, not mind blowing fast but a whole lot better.  All computers and our templates are set to cache model and layouts for regeneration, it helps immensly once all the tabs are cached.
Active Contributor
volusiajim
Message 26 of 27 (409 Views)
09-03-2013 10:14 AM in reply to: machadt
That did it for me.  Now I need to figure how it changed all by it's little lonesome.:smileylol:
New Member
depinkley
Message 27 of 27 (181 Views)
05-06-2014 09:14 AM in reply to: machadt
Thanks for the info!  This was driving me nuts!!  Cudos!
